Author Topic: BROKEN PIECE OF CASE  (Read 2502 times)
Offline JOEY11
« on: April 19, 2021, 08:06:49 AM »
I took the skid plat off my 85 to clean it since the previous owner hadn't done it often by the looks of it and while wiping it down with a paper towel I heard something metallic hit the ground. I found a piece of aluminum on the floor and looked around and found this. I recently replace this bolt a couple weeks ago and used a long extension with no ratchet to snug it up. I just JB welded the piece back in place but what could have caused it?
Re: BROKEN PIECE OF CASE
« Reply #1 on: April 19, 2021, 01:24:31 PM »
By chance do you have a picture of the broken piece?  I’d say at one time it was hit or maybe a too long of a bolt caused it to bust out???  I bet the previous owner might have attached the broken piece and just by luck it finally let go.
Offline evaneyeball
« Reply #2 on: April 20, 2021, 01:24:04 PM »
I second that. But I did have a part of my drain plug hole snap off while I was screwing it in by hand so it is more than possible that they were both just hit previously and just holding on
LED built 86 trx 350 CEO
81 ATC250r
Offline JOEY11
« Reply #3 on: April 24, 2021, 12:14:52 PM »
I didn’t take a pic of the piece before I slapped some jb weld on it. I think it was probably hit at some point and then when I tightened the bolt it finished the job.
