Author Topic: Swing arm bearings  (Read 5615 times)
Offline Banshee330
Swing arm bearings
« on: May 03, 2021, 11:37:37 AM »
Anybody know the actual toyo number on the 86/87 swing arm bearing?
Re: Swing arm bearings
« Reply #1 on: May 03, 2021, 10:07:55 PM »
The bearing dimensions are 20x26x30.  I just usually type in the bearing dimensions and bearing type to get the part number or at least the bearing manufactures catalog page.  In this case it’s a drawn cup needle bearing.  I’ll see what I come up with.
Offline Banshee330
« Reply #2 on: May 05, 2021, 11:36:48 AM »
Thanks, trying to come up with some dimensions to make a removal tool.
Offline Banshee330
« Reply #3 on: May 05, 2021, 07:18:07 PM »
Started to make something, then I didn’t have time. Came home and started looking, hmm 2 stiff drinks later I got one out with 2 sockets a touch of heat and a piece of all thread!
Offline Banshee330
« Reply #4 on: May 06, 2021, 06:32:13 AM »
Here’s the nomenclature on the swing arm bearing.
Offline atvmxr
« Reply #5 on: May 06, 2021, 01:17:30 PM »
for 86/87, doesnt someone make a hard poly version?
« Reply #6 on: May 06, 2021, 02:11:14 PM »
Helm Enterprises:
https://www.atvbushings.com/
I’ve also seen a few others on the FB pages make some over the years,
Offline Banshee330
« Reply #7 on: May 07, 2021, 06:42:09 AM »
Great information. I already bought a rebuild kit with needle bearings in it. I need to speak up for better advice before buying stuff. I got so much I want to do to this quad. Powder coat (no idea ) need a exhaust clamp for a PT and fat boy, when you buy aftermarket a -arms do they come with bushings? Looking for rebuild kits for master cylinder and all 3 calibers. Got a long way to go. Slowly but surely new parts are starting to pile up.
« Reply #8 on: May 07, 2021, 11:44:19 AM »
Aftermarket a-arms will be ready to bolt on if you buy them new... I've rebuilt 2 complete sets of brakes using Shindy rebuild kits & have no complaints, there high quality parts. If you need a rear mc push-rod Suzuki part number 69670-00A00.
Offline Banshee330
« Reply #9 on: May 28, 2021, 07:28:27 PM »
Any idea where this goes? I can’t find a home for it. It wasn’t on or bolted to the quad when I got it.
« Reply #10 on: May 28, 2021, 07:57:42 PM »
Lower chain slider.  Bolts to the frame.
Circled area
Offline Banshee330
« Reply #11 on: May 28, 2021, 11:20:37 PM »
Thanks Joe!
