Author Topic: Looking for a piston  (Read 7101 times)
Offline Texas30cal
« on: September 22, 2021, 10:18:48 PM »
Been looking for weeks, found several sellers that say they have it only to get refunded, looking for wiseco 66.75mm for long rod motor. Thanks!
Re: Looking for a piston
« Reply #1 on: September 28, 2021, 07:52:51 PM »
Good luck finding pistons.  I have a lot of engines and cylinders in my shop that have had pistons on order for over 6 months.  I need the pistons before I can bore them and get them put together.
 Don't blame me I voted for Trump. :)
Offline Texas30cal
« Reply #2 on: September 30, 2021, 10:01:32 AM »
I found a 67mm at Rocky Mountain 👍
« Reply #3 on: September 30, 2021, 10:48:51 AM »
https://fortnine.ca/en/wiseco-piston-kit
66.75mm 0.75 oversize for 1986 TRX250R (will work with long rod....just need a spacer plate & an extra base gasket)
In Stock - $211.99 CDN = $167.47 USD
« Last Edit: September 30, 2021, 10:50:45 AM by Langbolt »
Offline Texas30cal
« Reply #4 on: October 01, 2021, 12:11:53 AM »
I thought about milling the window in the intake skirt and using the spacer plate but didn’t really like the idea of the plate being visible , I know it’s not a big deal really but I just want things as clean as possible.
« Reply #5 on: October 03, 2021, 02:38:41 PM »
If you use the '86 style piston you don't have to machine it.....just add the Spacer Plate and another base gasket and you're good to go!  ;D
