Author Topic: Mounting shock reservoirs?  (Read 5452 times)
Offline atvmxr
« on: January 07, 2022, 09:27:13 AM »
You guys got any bright ideas how/where these TCS rezzies are supposed to mount?
There isn’t a 90elbow connection exiting the shock so mounting in the usual spot has the hose making a couple tight bends.   Gonna use the schmidty racing rubber mounts.
Hose is too short to mount behind radiator
Online The norm
Re: Mounting shock reservoirs?
« Reply #1 on: January 07, 2022, 09:39:59 AM »
I ran into the same issue when trying to mount my fronts. I went ahead and mounted them similar to your first picture. My axis shocks had 90° elbows and I was able to get a little better fit up by rotating the elbows.
https://www.imagebam.com/view/ME669SJ
Loren
« Last Edit: January 07, 2022, 01:46:48 PM by The norm »
« Reply #2 on: February 08, 2022, 09:03:32 PM »
Did you get these mounted?
Offline atvmxr
« Reply #3 on: February 11, 2022, 09:39:27 AM »
yep, like in the first pic. its goofy, but seemed to be the only option
