Author Topic: zeeltronic ignition  (Read 12493 times)
Offline bushwesl
Re: zeeltronic ignition
« Reply #15 on: March 02, 2023, 05:54:56 AM »
Quick update - I was able to get confirmation from Dave that my maps are OPPOSITE of what was advertised. My Map 1 above is CR250 (21.3 deg timing) and my Map 2 is TRX250R (18.0 deg timing). If I wouldn’t have gotten the cable to check them, I would have never known. Especially since I was planning on wiring my Zeel to be Map 2 only to use the CR250 map. If you wired a map switch to toggle between the two maps you could probably tell a performance difference and which is which, but for anyone considering wiring their Zeel without a map switch I’d strongly suggest that you get a cable to confirm your maps first.
Offline atvmxr
« Reply #16 on: March 02, 2023, 08:44:48 AM »
good deal, glad you got it sorted out!
Offline Antimullet
« Reply #17 on: March 20, 2023, 08:54:14 AM »
I have mine and am trying to setup proper. Couple questions.
1.  What did your static angle measure out at? I measured around 17.3 degrees. That has to be wrong so I’m tryin again.
2.  What did you lobe length angle measure out at?
I just am curious if I’m in the ballpark with those two measures and if there is a lot of variation between machines.
« Last Edit: March 20, 2023, 08:55:51 AM by Antimullet »
Offline bushwesl
« Reply #18 on: March 20, 2023, 08:43:54 PM »
I haven’t measured either of them, nor do I know how to.
All I know is how my Zeel is currently configured: 50.0* static angle and 31.3* lobe length.
Are your base settings from DRW the same as mine?
« Reply #19 on: October 13, 2023, 08:39:44 PM »
