Author Topic: DMR front hubs  (Read 3852 times)
Online croat1
DMR front hubs
« on: March 02, 2022, 07:51:36 AM »
Dave Moore is working on some front hubs.
« Last Edit: March 02, 2022, 08:51:47 AM by croat1 »
Online croat1
Re: DMR front hubs
« Reply #1 on: April 04, 2022, 12:43:22 PM »
Pic…..
Online croat1
Re: DMR front hubs
« Reply #2 on: April 17, 2022, 06:10:48 PM »
Mounted up
Re: DMR front hubs
« Reply #3 on: April 17, 2022, 10:54:37 PM »
Do you know if the dimensions are based on the 86-87 hubs or the 88-89's? I see there 3 bolt like the 88-89 but are styled like the 86-87..... Reason I ask is the 88-89 hubs have a 3/8" offset compared to 86-87 hubs so if you run 88-89 hubs/spindles on an 86-87 yor get an extra 3/4" width. I have some LSR micro-lites on my 86 which take the 4 bolt rotor but they have the 3/8" wider offset like the 88-89 oem hubs.
Online croat1
Re: DMR front hubs
« Reply #4 on: April 22, 2022, 11:44:46 AM »
Hmmm.  Good question kevin about what offset these are.  I’ll inquire and report back.
Side note:  Come to find out LSR had 2 offsets available for 86/87 hubs.  What I don’t know if they were available at the same time.
Online croat1
Re: DMR front hubs
« Reply #5 on: April 22, 2022, 11:46:27 AM »
Hopefully they will do a part revision and offer them with center caps.
Online croat1
Re: DMR front hubs
« Reply #6 on: August 21, 2023, 08:59:49 AM »
Soon to be discontinued
Offline All250R
Re: DMR front hubs
« Reply #7 on: August 23, 2023, 05:21:40 PM »
I'm not a fan of how the maching leaves raw aluminum to oxidize and turn gray. Same with any otherwise anodized part...
Offline All250R
Re: DMR front hubs
« Reply #8 on: August 23, 2023, 05:35:48 PM »
Another question, the 400ex front hubs are still available in red 44615-HN6-000. Are these mechanically/dimensionally the same as the 250R hub?
this post seems to indicate that the rotor bolts and width between bearings may be different. https://www.trx250r.net/threads/hubs-for-400-ex-spindles.10119/
