Author Topic: Build a Leak down test kit  (Read 4969 times)
Offline atvmxr
« on: January 29, 2023, 08:34:49 PM »
How do you plug/ seal off the exhaust side?
Intake I presume a 1.5” pvc fitting goes on intake boot with a hose clamp
Re: Build a Leak down test kit
« Reply #1 on: January 29, 2023, 09:50:34 PM »
What I have seen is the exhaust manifold is removed. Plate with rubber gasket is installed.
Possible a radiator hose would fit on the exhaust manifold and use a PVC plug .
« Reply #2 on: January 30, 2023, 01:46:50 AM »
I leave the exhaust flange on & cap it with a rubber pipe plug from home depot. I built my tester to connect to the intake so I could have the reed cage & spacer installed to be able to test those gaskets as well. I've had air leaks around both the exhaust flanges & reed spacers so now I always test with them in place.
« Reply #3 on: January 30, 2023, 11:07:50 AM »
I do the same as Kevin, test as many gaskets as possible while you are doing the test.
Loren
« Reply #4 on: January 30, 2023, 12:04:07 PM »
Get yourself a #9 rubber expansion plug :)
Pool stores have these for winterizing
« Last Edit: January 30, 2023, 12:06:39 PM by Langbolt »
