Author Topic: counterbalancer large bearing #TM16007  (Read 4859 times)
Offline All250R
« on: August 26, 2023, 01:35:16 PM »
Without checking the number printed on the OE bearing, a search in a few places on the forums revealed the part number to be 16007. The OE spec though appears to be NTN TM16007.
The two bearings are dimensionally the same but the load spec is different, the TM bearing having a higher load rating.
https://bearingfinder.ntnamericas.com/keyword/deep-groove-ball-bearings?key=all&keyword=16007&SchType=2
https://www.forums.trx250r.org/index.php/topic,8922.msg80494.html#msg80494
If you've had success running a standard 16007, that might be useful to have documented.
In the meantime, if you'd like the 16007 bearing I ordered, I'll send it to you for $20 shipped small flat rate usps just to cover cost and time.
Btw, counterfeit bearings are a problem. appllied.com is an "approved" dealer for NTN
$49.23 https://www.applied.com/c-brands/c-skf-corp/c-skf/16007/Cylindrical-Bore-Deep-Groove-Ball-Bearing/p/100756217
$52.82 https://www.applied.com/c-brands/c-ntn-bearing-corp-/tm-16007m3/Single-Row-Radial-Ball-Bearing---Open-Type/p/101814437
Re: counterbalancer large bearing #TM16007
« Reply #1 on: August 27, 2023, 01:02:40 AM »
Good info. Thanks for sharing!
Offline All250R
« Reply #2 on: August 28, 2023, 02:44:50 PM »
just to un-bury it into another post, if anyone is interested in the standard 16007 bearing I have, let me know. $20 shipped.
« Reply #3 on: August 28, 2023, 03:14:55 PM »
Here's the Specs if anyone wants to see the actual numbers ;) as well as the other alternatives with a different clearance (C3 & C4)
https://bearingfinder.ntnamericas.com/keyword/deep-groove-ball-bearings/single-row-radial-ball-bearings?key=all&keyword=16007&SchType=2
