Author Topic: rear brake lever seals  (Read 10568 times)
Offline All250R
« on: January 19, 2024, 11:50:20 AM »
The OE seals (91206-965-003, 19x25x3) are discontinued.
  These are a single lip, hard seal, meaning the outside diameter is likely metal encased in rubber.
91303-KA3-732, 19x25x4.1 is a suitable replacement.
  These are a single lip, soft seal used primary it seems for sealing kickstart levers.
  The extra 1mm width is a thin lip on the sealing side of the seal. It can be trimmed off easily by placing the seal upside down in the lever bore, and trimming the edge with a razor. If not, there is a small amount of friction in the action of the lever that wouldn't be there otherwise, as the seal protrudes slightly above the lever's plane so will rub on the washer and frame.
Online Langbolt
Re: rear brake lever seals
« Reply #1 on: January 20, 2024, 03:11:14 PM »
I've ordered a 7410 (pretty common seal) from my bearing supplier.
It measures:
19.05mm ID
25.37mm OD
3.18mm width.
https://www.skfextranet.com/crsealsfinder/datasheet.aspx?s=7410
I'll let you know how well it works :D
Offline All250R
« Reply #2 on: January 22, 2024, 01:33:51 PM »
It measures:
19.05mm ID
25.37mm OD
3.18mm width.
Yea if that works, that would be great. I couldn't find anything in metric.
Offline bholzgen
« Reply #3 on: January 25, 2024, 06:52:49 AM »
Let us know if it works!
Thanks
2002 Roll Design Lobo MX
2002 Laegers CRF450R Hybrid
1985 ATC 70
Online Langbolt
« Reply #4 on: January 28, 2024, 12:43:06 PM »
Well I Installed the #7410 Seal....it's a really close fit.....I used my hydraulic press so it would press it in perfectly square....and it worked!
It is a Steel shell with a single lip rubber seal.....so a dab of paint after install wouldn't be a bad idea to stop it from rusting.
Online Langbolt
« Reply #5 on: February 02, 2024, 11:11:41 AM »
I found another replacement: SOG seal #111870 19x25-3.5 (so 0.5mm thicker)
https://www.ebay.ca/itm/166271603986
:D
« Last Edit: February 02, 2024, 11:38:04 AM by Langbolt »
Offline 88trx
« Reply #6 on: February 08, 2024, 11:56:47 AM »
Thanks for the heads up.
