Author Topic: End of the year QOTM  (Read 6034 times)
« on: November 15, 2024, 08:16:40 PM »
End of the year quad of the month.  There will be no voting.  A winner will be chosen by a random number generator.
Winner will be chosen December 31st 2024.
Topic is anything atc/trx250R….a build, complete quad, riding picture….Fill out the list below or a short write up.
Enter now for the end of the year QOTM   Winner will receive a $50 gift certificate from Rocky Mountain ATV.  I am sponsoring this so the gift  comes from me.  This is the official thread so post here.
Thanks everyone. Good luck fellas.
QOTM Rules
   1.   One post per QOTM entry (i.e. no multi posts for the same entry).
   2.   You may post multiple entries (e.g. if you own 2 250R's, you may make 2 separate posts).
   3.   If you win, PM for gift certificate
   4.   No blatant advertising or promoting.
   5.   QOTM entries only (i.e. no commenting back and forth - this helps keep the thread clean.
   6.   Fill out QOTM entry template below (copy and paste) or a quick write up.
Failing to comply with these rules may result in removal of QOTM submission.
   1.   Frame:
   2.   A Arms:
   3.   Swingarm:
   4.   Steering Stem:
   5.   Axle:
   6.   Carrier:
   7.   Locknut:
   8.   Hubs F|R:
   9.   Bars:
   10.   Brake/Clutch Lever:
   11.   Grips:
   12.   Foot Pegs:
   13.   Bumper:
   14.   Grab Bar:
   15.   Front Shocks:
   16.   Rear Shock:
   17.   Brake Lines:
   18.   Rotors F|R:
   19.   Rims F|R:
   20.   Tires F|R:
Body:
   1.   Plastic:
   2.   Graphics|Seat Cover:
   3.   Fuel Tank:
Engine|Drive System:
   1.   Cylinder|Head:
   2.   Bore & Stroke:
   3.   Displacement:
   4.   Carburetor:
   5.   Reeds:
   6.   Air Filter|Box:
   7.   Pipe|Silencer:
   8.   Clutch|Plates:
   9.   Gearing F|R:
   10.   CDI|Killswitch:
   11.   Cooling:
Other miscellaneous information.
For the drawing (in order of participation):
1.  Blake
2.  Loren
« Last Edit: December 03, 2024, 06:17:49 PM by croat1 »
Re: End of the year QOTM
« Reply #1 on: November 15, 2024, 08:32:19 PM »
Picture for attention.  I’m not entering.  Laeger narrow front standard link rear.  Protrax ftont.  Laeger swingarm.  Peps front and back. 363 top end, cr ignition, Hinson clutch.
Post will be numbered in numerical order as they are posted
« Last Edit: November 15, 2024, 09:22:17 PM by croat1 »
Offline bholzgen
« Reply #2 on: November 20, 2024, 12:17:59 PM »
   1.   Frame: 2002 Roll Design Lobo MX
   2.   A Arms: Roll Design Lobo MX
   3.   Swingarm: Roll Design Lobo Gullwing No-Link
   4.   Steering Stem: Roll Design Lobo
   5.   Axle: RPM Dominator
   6.   Carrier: PRP
   7.   Locknut: RPM
   8.   Hubs F|R: Hardkor Engineering & Lonestar
   9.   Bars: Renthal CR High Fatbar
   10.   Brake/Clutch Lever:  Beringer BRO14 & Works Connection
   11.   Grips: ODI Lock On
   12.   Foot Pegs: LRD
   13.   Bumper: Duncan Racing
   14.   Grab Bar: N/A
   15.   Front Shocks: Custom Axis Pro-Air
   16.   Rear Shock: Custom Axis No-Link
   17.   Brake Lines:  Galfer
   18.   Rotors F|R Streamline
   19.   Rims F|R:  DWT Beadlocks
   20.   Tires F|R: CST Pulse MXR
Body:
   1.   Plastic: Fullbore
   2.   Graphics|Seat Cover: Fourwerx
   3.   Fuel Tank: IMS 4 Gallon
   1.   Cylinder|Head: ESR 310 Ported by RB Racing
   2.   Bore & Stroke: 72mm x 72.50mm
   3.   Displacement: 297cc
   4.   Carburetor:  Keihin 38mm Airstriker
   5.   Reeds: V-Force 3
   6.   Air Filter|Box: LED Intake and Filter
   7.   Pipe|Silencer:  LED 250C
   8.   Clutch|Plates: Hinson
   9.   Gearing F|R: 13 x 38
   10.   CDI|Killswitch: 2001 CR250
   11.   Cooling: AFCO
2002 Laegers CRF450R Hybrid
1985 ATC 70
« Reply #3 on: December 03, 2024, 02:51:20 AM »
Chassis/ suspension / controls
1. Frame : stock 1986 gusseted
2. A-Arms: +3-+1 burgers
3. Swing Arm: +3 (modified 88/89 +4) Ace Fabrication
4. Steering stem: +2-+1 LK custom fab
5. Axle: Lonestar Excalibur +4
6. Carrier: Lonestar
7. Locknut: OEM
8. Hubs F/R: OEM
9. Bars: ProTaper Pastrana bend
10. Brake/ Clutch lever: Brake-OEM / Clutch- Magura
11. Grips: Oury
12. Foot pegs: LK custom fab monster pegs
13. Bumper: AC Racing
14. Grab Bar: AC Racing
17. Brake Lines: Streamline
18. Rotors: OEM
19. Rims F/R: Alba Racing headlocks
20. Tires F/R: Skat Trak Mohawk/Haulers
Body:
2. Graphics/Seat Cover: N/A/ Cascade ATV Seats
3. Fuel Tank: OEM 1986 with Pringle valve
Engine/Drive System:
1. Cylinder/Head: ESR/ESR
2. Bore & Stroke: 81.5 x 76
3. Displacement: 396.48 cc
4. Carburetor: Keihin 40.5 PWK
5. Reeds: Vforce 3
6. Air Filter/Box: Vision Air carbon fiber/S&B Filter
7. Pipe/Silencer: CPI/LK Custom Fab 13” Silencer
8. Clutch/Plates: Wiseco Hard Anodized Basket/Tusk Frictions and Steels/Gigot Lockout
9. Gearing F/R: 14/38
10. CDI/Kill Switch: 1999 CR250/OEM TRX250R
11. Cooling: PWR Radiator
This R is ever evolving and has been a well used long term project 12 years in the making……
« Last Edit: December 03, 2024, 03:00:19 AM by The norm »
« Reply #4 on: December 31, 2024, 05:55:19 AM »
@bholzgen
@The norm
Well that’s a wrap folks.  Hope everyone had a great year.  Instead of picking a winner from the 2 participants I decided to give each a gift card to RMATV.  Blake for the aftermarket frame win and Loren for the stock frame win.  Guys text or message me your email information please.
