Author Topic: O - Ring Size for Hinson Clutch cover ?  (Read 11374 times)
Offline Justin4141
« on: December 10, 2025, 01:45:37 AM »
Was just wondering if you guys can help me out with the size of the o-ring for the inner Hinson clutch cover before I go to the hardware store an play a guessing game on the o-ring size…
Re: O - Ring Size for Hinson Clutch cover ?
« Reply #1 on: December 10, 2025, 04:17:21 PM »
Should be able to measure the ID of the case groove with a tape measure. If you have calipers, I would measure the depth of the groove. Target an oring cross section ~0.5mm larger. A good website to use is McMaster Carr. With ID and cross section you should be able to find a standard size that you can cross reference to your local hardware store.
Unfortunately I don't have a case readily available to measure.
Best regards
-Jason
Offline Justin4141
« Reply #2 on: December 11, 2025, 05:54:58 AM »
Found out it’s  140mm x 3mm
Online croat1
« Reply #3 on: December 12, 2025, 08:07:53 AM »
As Jason stated McMaster Carr is my go to.  Great company.
McMaster Carr O ring number is:
1302N194
