Thanks for all the replies guys!Thesmith87250r - I agree with you that things should last longer, but unlike stock A-arms that have bearings in them, these are older model Laeger's with only the Derlin bushings and no grease zerks. However, each winter I did pull the front-end off and hand smear grease on the bolts, sleeves and bushings. Also the terrain that I ride is mostly woods trails, but once a year my group travels out of state to some kind of extreme ORV park or area. Was out in Moab, UT this past September and the front end took some really hard hits on the rocks (why I need new tie rod ends). My typical riding season is: 1 Saturday afternoon on a MX track, 4 ~ 5 week-ends of trails in northern Michigan, 1 - three day ride in Michigan's Upper Peninsula and 3 days at an out of state location (usually mountains and rocks). Yes, the replacement bushings were direct from Larger's and were sloppier than the ones that came with the arms when I bought them used. As for the sleeves - I used the ones that came with the arms, as well as the ones that I got from Laeger's. I had the nephew make the Delrin bushings so there was a little interference fit on the A-arm tube and a very nice slide-through fit between the sleeve and the bushing. You know, how bushings should fit. Where as the stuff from Laeger's had about a 0.035" clearance on the sleeve to bushing and about 0.100" clearance on bushing to tube.The nephew actually recommended UHMW instead of the Delrin.As for if they are 400EX arms vs. 250R arms - I don't know. There are no identifying marks on these arms other than the Laeger's stickers. Are there dimensions that could be checked to determine what I have?
