Author Topic: LED 350 Sphynx XC Build  (Read 64620 times)
Offline TLR-Online
« Reply #75 on: April 19, 2014, 09:31:21 AM »
Do you have a pic of the case saver with the stator cover mounted (from the front)? Will the shifter fit on there ok?
Offline Higgy87trx425
« Reply #76 on: April 19, 2014, 06:01:58 PM »
Quote from: Tbone07;31065
Got some good work done this weekend. The motor went in without a hitch, and got the LED 350G pipe all mounted up. Initially it was a pain to mount but once I got it adjusted it fits perfectly and is mounted very solid. Unfortunately the bolt hole on the Laeger headstay doesn't line up with the Sphynx head, but i'll need it for my steering stabilizer
I'm able to get about 3.5in of adjustment out of the pipe but i'll need some longer bolts if I want to go that far. I'm not sure how much of a difference the adjustments will make power wise, but it really helped with fitment of the pipe. It's tough fitting that bigger header through a Laeger narrow frame.
Thats a sexy lookin pipe!!! I'm a little worried about how mine is going to mount up!! I'm liking the build!!
 Thanks Higgy
Offline bnau267
« Reply #77 on: April 19, 2014, 06:19:02 PM »
Quote from: Tbone07;31479
It's a monster lol. I think it will be perfect and I wouldn't hesitate to buy another one. I think a lot of cases could have been saved if they had this to protect them. Those little aluminum savers don't do squat
I think the case saver was $59.95, it's on UPP's site if you need to check it out
I'm hook-line-sinker on those case savers too.  I love mine.
« Reply #78 on: April 20, 2014, 03:47:24 PM »
Quote from: TLR-Online;31853
I do not have a pic of it mounted with the stator cover yet. I'll have one soon. After looking at it closely it looks like it will fit fine
The shifter will definitely fit
« Reply #79 on: April 22, 2014, 12:20:00 PM »
I got the stator cover on there yesterday and it fit pretty well. It rubs the case saver slightly, but went on pretty well.
« Reply #80 on: April 22, 2014, 12:22:43 PM »
So I mounted up my rear shock to check clearance with my pipe and my worst fear was confirmed....the stinger hits the shock pretty badly.
My buddy @ HMF has my swingarm to weld rotor guard mounts, so when I get a roller i'll get it in there and he can use the pipe bender to make it fit perfectly. I'm lucky to have HMF about 5 minutes from my work
« Reply #81 on: May 08, 2014, 10:58:32 AM »
Here's the LED 350G after my buddy @ HMF modified it for me. Really should have told Arlan what frame I had, i'll take the blame for that.
Also fabbed me up a beefy stainless rotor guard
Offline ryanowarrior
« Reply #82 on: May 08, 2014, 04:03:05 PM »
But still wouldn't have been able to make the bend would he since he doesn't have a frame to go by? I want another one of these pipes but that's my only downfall
Laeger Crf
Laeger R
Walsh R
Walsh Crf (in the works)
« Reply #83 on: May 08, 2014, 05:07:14 PM »
He might have one to go off of, i'm not sure. I neglected to even mention it to him or ask him
« Reply #84 on: May 08, 2014, 05:47:28 PM »
Good to see some updates!  When is this thing going to be all buttoned up?
Offline bnau267
« Reply #85 on: May 09, 2014, 09:55:49 PM »
Quote from: Tbone07;33530
I may be in the same boat with the shock and headstay....LOL.  Can't wait!  Didn't even think about that.
Offline bnau267
« Reply #86 on: May 19, 2014, 12:52:36 AM »
[MENTION=483]Tbone07[/MENTION] hope you don't mind.  This is my beat to hell 86 engine but this is what the UPP saver looks like mounted.  And yes I know my chain has seen better days but who cares when you have one of these bad boys installed.
« Reply #87 on: May 19, 2014, 01:33:40 PM »
Quote from: bnau267;33603
But my Sparks MX pipe fits perfectly....
Quote from: bnau267;34329
@Tbone07 hope you don't mind.  This is my beat to hell 86 engine but this is what the UPP saver looks like mounted.  And yes I know my chain has seen better days but who cares when you have one of these bad boys installed.
Don't mind at all. Those UPP case savers are the bee's knees, a very good investment
Offline TLR-Online
« Reply #88 on: May 19, 2014, 04:36:25 PM »
I actually ordered one awhile ago. Very nice... really snug fit. Only problem, I had to swap out the 10mm bolts heads for 8mm bolt heads. I couldn't fit my socket inside the holes.
« Reply #89 on: May 26, 2014, 10:36:45 PM »
Looks like my project is gonna take a little longer now
