Author Topic: Is this a Hybrid too? (Updated)  (Read 62038 times)
Offline mrtwidster1
85 cr Jug and 01 cr ignition
« Reply #30 on: February 14, 2014, 10:00:31 AM »
1985 CR jug that will end up on this build.
Along with this Ignition
« Last Edit: February 14, 2014, 10:21:36 AM by mrtwidster1 »
Offline mrtwidster1
« Reply #31 on: February 14, 2014, 10:07:50 AM »
TRIPPLES
Start
Mid way
Finish
Offline mrtwidster1
« Reply #32 on: February 14, 2014, 10:14:02 AM »
Pegs
Start
Mid
Installed
« Last Edit: February 14, 2014, 10:42:44 AM by mrtwidster1 »
Offline mrtwidster1
« Reply #33 on: February 14, 2014, 10:14:52 AM »
Stainless Swing arm Bolt
Stainless Brake petal
Offline mrtwidster1
« Reply #34 on: February 14, 2014, 10:30:04 AM »
Went ahead and put some "build" pics here.
« Last Edit: February 14, 2014, 10:34:59 AM by mrtwidster1 »
« Reply #35 on: February 14, 2014, 10:59:04 AM »
You've been busy. What forks are you using? What did use to cut the pieces for your pegs? Looking good anyway.
Offline mrtwidster1
« Reply #36 on: February 14, 2014, 11:09:17 AM »
Not too busy, Taken almost 5 yrs. Trying to keep the cost down as much as I can.
KTM 85sx forks with stiffer springs.
Pegs are made from perforated metal. Came from scrap.
Wish they were stainless, but Oh well.
Thanks
Offline mx250r91
« Reply #37 on: February 14, 2014, 11:57:22 AM »
Nice I've always wanted to do the 85 CR cylinder on my 85. Love the look of the big water jacket over the exhaust port. Bet it runs good too! Did you have to make a custom exhaust flange?
Offline mrtwidster1
« Reply #38 on: February 14, 2014, 12:06:04 PM »
Quote from: mx250r91;25532
Thanks. Yes on the flange. Had a Turned a stainless mounting disc on the lathe made, then had a Tigged a cut off flange to it. Post 34 shows it some.
« Last Edit: February 14, 2014, 12:59:30 PM by mrtwidster1 »
Offline mrtwidster1
« Reply #39 on: February 14, 2014, 01:33:36 PM »
Swinger
06 TRX 450r extended 2 inches
Start
Mid way
Finished
Offline Fire1
« Reply #40 on: February 14, 2014, 05:36:02 PM »
Great work Tony!
Offline mrtwidster1
« Reply #41 on: February 14, 2014, 06:48:59 PM »
Thanks Tim!
Great to hear from you. Hope all is well, and that you have dug out of the snow. You get in the Snow plow business?? May need to consider putting a plow on a couple of those mowers!!
Offline mrtwidster1
AIR BOX progress
« Reply #42 on: February 22, 2014, 08:42:47 PM »
Pic of airbox "Roughed In" Still need to fab and install mounting hardware. Just mocked up now for fitment and then dis_assembled. Will polish or powder coat.
Offline mrtwidster1
Little Power coating accomplished
« Reply #43 on: April 06, 2014, 10:55:55 AM »
Few more pics.
Offline mrtwidster1
Rear skid plate progress
« Reply #44 on: April 06, 2014, 11:00:36 AM »
Rear skid plate Mocked up. Still have some tweaking and cosmetic's
« Last Edit: April 06, 2014, 08:12:45 PM by mrtwidster1 »
