Author Topic: Engine Paint  (Read 10356 times)
Offline bnau267
Engine Paint
« on: January 01, 2014, 09:03:24 AM »
I'm looking to refinish my cases in a flat black satin (like a stock 89).  My question is simple.  Are there any advantages to painting or any pitfalls using powder?  If paint is the way to go, does anyone have a PPG code for the stock 88/89's?  For Powder, is there a special spec needed to handle the heat?  Also, can the bearings be left in?  Finally, lets see some finished product!
Engine Paint
« Reply #1 on: January 01, 2014, 10:02:36 AM »
take a look a pumashines cases.  he uses paint and its always looks wet and looks awesome.
Offline Bigred
Engine Paint
« Reply #2 on: January 01, 2014, 10:29:34 AM »
Ppg u can use wa 8555. Its gm black then just add a flatning agent to the clear
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
Engine Paint
« Reply #3 on: January 01, 2014, 11:22:52 AM »
I use VHT high temp paint, not really necessary to be high temp but it work good.
Engine Paint
« Reply #4 on: January 01, 2014, 11:38:40 AM »
Honestly, a rattle can, would fool many people! Looks great and holds up well. :Boobies2:
Offline bnau267
Engine Paint
« Reply #5 on: January 01, 2014, 01:01:23 PM »
Any thoughts on Powder?
Engine Paint
« Reply #6 on: January 01, 2014, 02:47:18 PM »
Quote from: bnau267;21114
You have to remove the bearings. Paint would be better, if you don't want to replace them.
Offline xTHUNDERCATx
Engine Paint
« Reply #7 on: January 01, 2014, 06:03:53 PM »
i powdered mine, my next set will be painted when i get around to buying them. Paint will be easier to touch up if something scratches and can be done quickly is how im thinking about it.
Engine Paint
« Reply #8 on: January 02, 2014, 08:27:24 AM »
What do all you painters use to protect it from gas? With jetting so often on our R's, i've found the gas just eats the paint. Is there a special clear anyone is using?
Offline Iceracer
Engine Paint
« Reply #9 on: January 02, 2014, 09:05:56 AM »
So far The ceramic engine paints seem to hold up well. there designed for this application. I just did one of my personal project's with it also. I'll let you know how it hold's up.
Offline Bigred
Engine Paint
« Reply #10 on: January 02, 2014, 12:27:16 PM »
Automotive clear
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Engine Paint
« Reply #11 on: January 02, 2014, 02:00:32 PM »
Quote from: Bigred;21192
Automotive clear
Do you spray it out of a gun or do you have a rattle can made? My paint supplier offers the rattle can, kinda neat for painting the underside of a tailgate or wheel wells, etc.
Offline Bigred
Engine Paint
« Reply #12 on: January 02, 2014, 09:00:38 PM »
U can use the dpray can that they make its a one time use only tho just a fyi bc it has a hardener in it
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
Engine Paint
« Reply #13 on: January 02, 2014, 09:05:50 PM »
This is my bottomend I painted with ppg car paint
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Engine Paint
« Reply #14 on: January 03, 2014, 01:28:26 AM »
That looks really good!  Nice job.
