Author Topic: Laeger XC "ONE of ONE"  (Read 79108 times)
Offline bnau267
« Reply #60 on: August 07, 2014, 12:02:03 AM »
Engine almost done.  Other side will be revealed soon!
« Reply #61 on: August 07, 2014, 08:20:07 AM »
Nice! :Boobies2:
Offline bnau267
« Reply #62 on: August 10, 2014, 12:11:15 AM »
Found me some protection!
« Last Edit: August 10, 2014, 12:53:39 AM by bnau267 »
Offline HAYESTRX250R
« Reply #63 on: August 18, 2014, 01:35:07 PM »
This is motivation to get back on my build.
Offline bnau267
« Reply #64 on: September 04, 2014, 11:47:56 PM »
Got a lot going on right now so I haven't been able to do much...this bad boy arrived.
Offline mandom250r
« Reply #65 on: September 05, 2014, 02:56:32 AM »
They still make these new? How much?
Sent from my LG-P999 using Tapatalk 2
Offline bnau267
« Reply #66 on: September 09, 2014, 12:36:52 AM »
Quote from: mandom250r;42295
Too much
« Last Edit: September 15, 2014, 10:34:02 PM by bnau267 »
Offline bnau267
« Reply #67 on: September 14, 2014, 11:28:27 AM »
Anyone ever have to trim out a small section of the seat pan to clear the rear shock tower?  I hear it happens from time to time but wanted to be sure before cutting a hole in a NOS OEM Honda seat...
Offline bnau267
« Reply #68 on: September 14, 2014, 11:35:10 AM »
Gave up on finding a NOS RPM 250R XC axle so I went with their 400ex XC axle.  RPM modified a 250r anti fade (took a hair more than 3/16") so I had plenty of clearance for the snap ring.  Doesn't sound like a lot unless you've tried to run a R anti fade on a 400ex axle.  It worked out perfect like it was meant to be.
The hub to hub measurement is within 3/16" of the stock R.  If you look real close you can see how much room I have to work with now.
Offline bnau267
« Reply #69 on: September 14, 2014, 11:37:53 AM »
Here's the two skid plates I'll be running most of the time.  Scott is building me a new swing arm to accept both this and the traditional protect.  The new swingarm will run a 400ex chain slider instead of the R so it can be changed without ripping the bike apart and I'll be able to run Honda parts.
Offline bnau267
« Reply #70 on: October 01, 2014, 12:30:33 AM »
Made a little progress.  Waiting on the swinger....
« Last Edit: October 05, 2014, 02:44:41 PM by bnau267 »
« Reply #71 on: October 01, 2014, 08:16:36 PM »
Looking good. I did have to trim the fenders a little where they contact the upper rear shock mount. The pc wore off a couple of spots quickly also.
Offline bnau267
« Reply #72 on: October 05, 2014, 02:44:08 PM »
450 Front brake setup...
Offline bnau267
« Reply #73 on: October 05, 2014, 02:47:58 PM »
New Laeger swingarm finally showed up...
Offline bnau267
« Reply #74 on: October 05, 2014, 02:50:00 PM »
Swingarm up close.  Setup to run 400ex chain slide and can run either 450 or 250 skid pan.
