Author Topic: Rear caliper spacer??  (Read 7799 times)
Offline Higgy87trx425
« on: April 06, 2014, 07:02:17 PM »
I'm having issues getting the rear caliper to line up with the rotor. Its about an 1/8 inch off. Everything is aftermarket. Has anyone else had this issue? What am I missing?
 Thanks Higgy
« Reply #1 on: April 06, 2014, 07:12:00 PM »
This is one of those..
:thread_pics:
Can't say I've had any serious issues with alignment.. hopefully something is just missing or slightly out of whack.
« Reply #2 on: April 06, 2014, 07:17:09 PM »
LMAO Where's the pics Keith ?
« Reply #3 on: April 06, 2014, 09:36:00 PM »
Quote from: Pumashine;30993
:lol:
I'd love to add this to the smiley list but it'd just get abused way too much!!
« Reply #4 on: April 06, 2014, 09:53:42 PM »
Ok here ya go. See how the caliper is pushed all the way over and it still won't clear the rotor! Not sure what i'm missing?
Thanks Higgy
Offline DnB_Racing
« Reply #5 on: April 06, 2014, 10:02:00 PM »
are you sure the anti fade is in all the way? it looks like a space between the bearing holder and the rotor hub
« Reply #6 on: April 06, 2014, 10:05:22 PM »
It's pretty common to run washers. I just had to do it on my wife's. However I agree, it doesn't look like the antifade is all the way on...
« Reply #7 on: April 06, 2014, 10:14:07 PM »
If it is in all the way you might need to take if off and grind a 1/8" off of it.
« Reply #8 on: April 06, 2014, 11:02:14 PM »
Quote from: Pumashine;31015
Ok, I may have to take about 1/8 off of the anti-fade. How do you feel about using washers to shim it out?
 Thanks Higgy
Offline DnB_Racing
« Reply #9 on: April 06, 2014, 11:21:32 PM »
you might get the anti fade to move some after a small ride, try the washers to see if it will move after a little bouncing around, if it is indeed in all the way, I think I would do as Tony said and shorten it up a bit.. but its your quad, washers would bother me as a permanent fix in this situation
« Reply #10 on: April 06, 2014, 11:58:11 PM »
So I measured the end of the anti-fade and its almost .600? I'm just wondering if thats a standard length? Before I modify it. Also I wonder if my bearings are pressed in all the way?? Has anyone else had to grind off material? It seems a bit drastic.
 Thanks Higgy
« Reply #11 on: April 07, 2014, 12:09:42 AM »
Quote from: Higgy87trx425;31024
Has anyone else had to grind off material? It seems a bit drastic. Thanks Higgy
I had to take that much off when mix and matching a 400 EX axle.
« Reply #12 on: April 07, 2014, 12:18:14 AM »
Quote from: Pumashine;31025
Ok thanks, so I may have a 400ex axle. The axle I got came with a frame that I bought. The guy just threw it in.
 Thanks Higgy
« Reply #13 on: April 07, 2014, 12:23:55 AM »
Quote from: Higgy87trx425;31026
I was able to just take the threaded piece and take it down with a surface grinder
Offline silverlake250r
« Reply #14 on: April 07, 2014, 11:50:19 AM »
Yeah grind it down. Washers are not a good way to fix anything ever. It looks extremely trashy.
2002 Roll Design Lobo MX
