Author Topic: ESR 330 Failure  (Read 57950 times)
ESR 330 Failure
« Reply #90 on: October 07, 2013, 10:06:43 AM »
Quote from: Langbolt;14004
Great to hear!!!
So what  Needle are you using ? Clip position ?
I was pretty satisfied, with they way she was running, using a DGH. But the clip was at the lowest groove. I messed with the main, going richier, came back to a 185, seemed good.
So a tried a DEJ, I never could find the sweet spot, moving up the clip. I went back to the DGH, plug looks great, bike runs great. Pop Pop is HAPPY! :onthego:
ESR 330 Failure
« Reply #91 on: November 21, 2015, 10:56:49 PM »
Quote from: F-Red;14140
Anymore issues?
Offline Saber569r
ESR 330 Failure
« Reply #92 on: November 22, 2015, 10:01:03 AM »
I had this same problem with a 310 kit but it was their pro-x cylinder. Turned out to be be a ignition problem. The pos builder didn't hook up a couple wires right. Caused me hell.
ESR 330 Failure
« Reply #93 on: November 22, 2015, 12:51:37 PM »
Quote from: Saber569r;61196
The builder didn't hook up a couple wires right. Caused me hell.
Time to switch to liberty builders company. You will be able to run 100% of your motor.
Offline pantera1975
ESR 330 Failure
« Reply #94 on: November 22, 2015, 11:13:25 PM »
I had led rebuild my 330 esr motor stock stroke cut the head for 50/50 fuel and run 91/110 mix 32/1. It stays cool til I got on loose sand and it would fo from 180 to over 200 fast. In my atc. I read my temp off tge top front line on the head. I fot new radiators that are over sized to try plus I went with some advise and ran big gearing which I think works it to hard at joy riding speeds. Plus I run all 3 6 ply tires. Im switching tires to all 3 cheetahs and gearing back to something like 14/38. Only way it would stay cool was to ride a physically hard as I could.
