Author Topic: Post your quad & dyno sheets  (Read 13005 times)
Offline Sand_Blaster
« on: May 05, 2014, 08:20:13 PM »
Over on bhq its a big deal whos making the most hp..So lets see what us R folks are making(not that it matters lol)
I'll start
42 before tune
50 after
heres the curve
ESR 310, ported by Nate
LRD exhaust LED SA Silencer
39mm Carb
Vforce 3 reeds
Ebay intake
Advanced timing
Heres a vid for fun
http://youtu.be/__IMvmda5EA
87 Trx250r & 99 Banshee
Offline patman13mia
« Reply #1 on: May 05, 2014, 08:23:38 PM »
Sick bike dude
Offline zcarlson12
« Reply #2 on: May 05, 2014, 09:20:57 PM »
Real nice Sand Blaster.
« Reply #3 on: May 05, 2014, 11:25:03 PM »
Nice bike and beautiful lake in the background. Where is that?
Online Jerry Hall
« Reply #4 on: May 06, 2014, 12:20:40 AM »
Quote from: Sand_Blaster;33191
I'll start
42 before tune
50 after
heres the curve
39mm Carb
Vforce 3 reeds
Ebay intake
Advanced timing
Heres a vid for fun
Why did the dyno guy compare power and an air/fuel curves using dyno runs made in different gears? The length (time) of the dyno runs between 5th and 6th gear can be enough to change the shape the power curve.  Did the dyno guy remove the sniffer tube from the muffler after he was done tuning and make a few more runs to check and see how much the sniffer tube could have been affecting the power and piston temperature??  Most engines need to be richened slightly after removing the sniffer tube and reducing the restriction the sniffer tube adds.
Do you have the run files from the dyno?  Not pictures of the dyno sheets but the actual data files that are on the dyno computer.  If so, send them to me if you want me to look at information that could possibly make it run better and or more reliable.
« Reply #5 on: May 06, 2014, 06:23:29 PM »
You know Jerry I have no clue why he did it that route & why he only threw in one main jet & called it good. I know if he would have spent more time tuning he could have sqeezed more power at it. It still runs like garbage, worse actually. I Know hes mostly a 4stroke guy & probably knows nothing when it comes to 2strokes..  I had my dad drop it off to him & dad picked it up, the fella said it was good to go.I was watching Arlen dyno some 250r's & it looked like he did it way different. Hmmm
Offline Bigred
« Reply #6 on: May 06, 2014, 08:57:47 PM »
Going for another run had to fix some issues
My 2014 version of a stock 250r
« Last Edit: May 06, 2014, 10:07:05 PM by Bigred »
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
Offline Wes350x
« Reply #7 on: May 06, 2014, 09:53:56 PM »
My buddy's ESR 420 with an oof pipe, 40.5 keihin, cr ign, trx11 port...  He was somewhat disappointed lol. He was told should be about a 70hp motor.
My old FTZ built pilot cylinder 390, 40.5 keihin, cr ign... The tuner said "something doesn't seem right" lol. I shipped the motor back to FTZ to have the. Check all port timings etc... They said it was fine. I switched the carb over to a 44mm Lectron and it did run better but still was a disappointment for how big the motor was. But it had torque like a train at least...
1988 250R
Offline Rupp250
« Reply #8 on: May 07, 2014, 11:15:04 AM »
DUNER -86 250R  Flinstone
Offline Rupp250
« Reply #9 on: May 07, 2014, 09:26:08 PM »
Here is my 363 Sphinx on Alky(with Shearer OOF) compared to 110(trx5cm)
Offline Rupp250
« Reply #10 on: May 07, 2014, 10:02:53 PM »
One on Alky & OOF, other 110 and TRX5CM
« Last Edit: May 07, 2014, 10:34:40 PM by Rupp250 »
Offline Bigred
« Reply #11 on: May 07, 2014, 10:19:27 PM »
Rupp looks like a big improvement
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Rupp250
« Reply #12 on: May 20, 2014, 03:31:01 AM »
Any more out there?
Online Jerry Hall
« Reply #13 on: May 20, 2014, 12:44:46 PM »
Quote from: Rupp250;33427
Would you display the time VS HP graph of the above runs?
« Reply #14 on: May 20, 2014, 09:33:27 PM »
[MENTION=167]Morse250r[/MENTION] have any of the RB stock top end dyno?
