Author Topic: Standard travel +2 shock upgrade options  (Read 11068 times)
Offline Bowtie316
« on: July 12, 2014, 08:34:14 PM »
I'm making some changes to and rebuilding my 88 trx250r, adding standard travel +2 arms and want to upgrade the shocks along with it. I have some old worn out works triple rates that are in pretty rough shape, would need rebuilt, revalved, painted, polished etc, I figure I would probably have $400 or more getting all that done.  Is there a better option?
I see works steelers for around $510 and elka stage 1 for $600, would I still need to get these revalved or could I get them set up for that price?
I don't really want to spend much more than that.
And as for reservoirs, I would prefer a piggyback type.  Are there other options out there using 450 shocks or anything that would be worth looking into?
« Reply #1 on: July 13, 2014, 01:38:49 AM »
I see Maultech is selling the hls's now. Sounds like the 450 shocks would run $600-$700 hundred all in.
Offline Bowtie316
« Reply #2 on: July 13, 2014, 08:10:36 AM »
For some reason I thought I read on Gt thunder site that HLS was no more. I will look into that, thank you.
Sent from my SGH-T679 using Tapatalk 2
Offline Quinnlt4
« Reply #3 on: July 13, 2014, 11:48:28 AM »
I had 450r shocks on +2 and the front sat higher and were stiff. I bought them for 150$ and looked into getting them redone, 500$ more, then found some 450r shocks that were setup up for a 250r.  Then I found some custom axis dual rate for 250$ set close to my weight. They are awesome. The hls essentials are a great shock at a great price. Friend runs them on a 400ex and is close to my weight. Similar to my axis.  I hope they still are making them, my next set was going to be the HLS elites...
1986 Laeger wannabe
Offline Quinnlt4
« Reply #4 on: July 13, 2014, 11:54:28 AM »
Also in my opinion, if you get a good shock builder to set up your shocks and readjust them for you to get them just right you don't need adjustable shocks unless you are a racers. Me, I would just get them out of whack, rather have someone who knows mess with them.
1986 Laeger wannabe
« Reply #5 on: July 13, 2014, 12:07:48 PM »
Quote from: rk88r;38833
http://www.gtthunder.com/
« Reply #6 on: July 13, 2014, 12:35:09 PM »
So with the passing of Laz is GT thunder no more?
« Reply #7 on: July 13, 2014, 01:21:49 PM »
Never mind i was wrong.
Offline Bowtie316
« Reply #8 on: July 13, 2014, 04:03:02 PM »
I'll probably call maultech anyway and see what they say.
Offline Bowtie316
« Reply #9 on: July 16, 2014, 09:55:47 PM »
HLS Essential it is.
Offline Quinnlt4
« Reply #10 on: July 17, 2014, 10:38:43 AM »
You get them from GT or Andy?
1986 Laeger wannabe
Offline Bowtie316
« Reply #11 on: July 17, 2014, 11:03:44 AM »
Quote from: Quinnlt4;39263
One in the same now. Haven't ordered yet, but will today if I have time.
« Reply #12 on: July 17, 2014, 11:13:37 AM »
GThunder is no more
« Reply #13 on: July 17, 2014, 11:41:13 AM »
HLS suspension, to a certain extent, is also no more. Andy will still be selling replacement parts for them for a while. They are being rebranded and setup by Maul Tech and will now be called GT Suspension.
Offline muthahucker
« Reply #14 on: July 17, 2014, 08:58:17 PM »
Try a site sponser Schmidty racing.  I got a front set of Works with external res and a stock rear shock done this spring, setup for +2 fronts and for my weight.  Just got out to try them last week and they are great.  I would recommend his work to anyone
