Author Topic: Big bore cylinders  (Read 6190 times)
Big bore cylinders
« on: September 12, 2015, 12:52:13 AM »
Just trying to learn something. What are the benefits to each of the cylinders out there.
Big bore cylinders
« Reply #1 on: September 12, 2015, 08:44:29 AM »
alot of it comes down to what you are willing to spend.
John
Offline dem3500
Big bore cylinders
« Reply #2 on: September 12, 2015, 10:08:35 AM »
More power and the price your willing to spend.
Big bore cylinders
« Reply #3 on: September 12, 2015, 12:08:09 PM »
I guess I'm looking for a more in depth look into them. Like is the differences in the CPI cylinders Just the size bore they can go or is it also port design
Big bore cylinders
« Reply #4 on: September 12, 2015, 12:23:47 PM »
I'm not an expert so I can't really help other than to suggest give Pete at hybrid engineering a (360) 281-2274. He is in washougal. He helped me out.
Big bore cylinders
« Reply #6 on: September 12, 2015, 01:33:00 PM »
That's a good post
Big bore cylinders
« Reply #7 on: September 12, 2015, 01:34:56 PM »
Hickwheeler, I have a prox 310 at home. I can't explain the difference in port design but I'll be happy to show you the ports in my prox vs stock.
Big bore cylinders
« Reply #8 on: September 12, 2015, 01:44:02 PM »
my cylinder on my bike is a pro x 330. Just not sure what direction I want to go.
Big bore cylinders
« Reply #9 on: September 12, 2015, 03:46:58 PM »
Quote from: hickwheeler;58460
What are your expectations from your engine?  What type of riding will the engine be used for?  What is your budget on the project?
The big question is:  Will the pipe you are going to use be optimum for the type of cylinder, porting, reeds, carb and head?  You can have a good combination of porting, reeds, carb and head with the wrong pipe and you will have an engine package that is an underperformer!  You can have a good combination of pipe, reeds, carb and head and have the wrong porting and you will have an engine package that is an underperformer!
There are design differences in the Pro-X 330 and the ESR 330s but will perform very similar if you have the basics (Pipe and porting) working together.  I like the exhaust port design of the ESR cylinders but I think ESR missed it on how the coolant circulates through the cylinder.  I like the reed cavity on the Pro-X cylinder and the intake port window on the ESR but it appears to me that an error was made when making the core box for the reed cavity on the ESR cylinder.  Rather than making a new core box, it appears to me the reed gasket surface was cut at a different angle to make the carburetor clear the frame cross member.
In summary:  The ESR of Pro-X cylinders work real well when you find an engine builder that has DONE THE TESTING so that he can recommend a pipe or can build a pipe that compliments the rest of the builders engine package.  Please do not show up at your engine builders shop with a box full of parts (pipe, cylinder, carb, reeds and ignition) and say port my cylinder for woods, or port my cylinder for dunes or port my cylinder for XC, .....etc.  We see this happen on a weekly basis and often we cannot build the engine package the customer wants because the customer brought us the wrong parts in the box.  It is like bringing all of the ingredients it takes to make chocolate chip cookies to a baker and ask him if he can make the cookies taste like oatmeal cookies using the ingredients you supplied.:joyous:
« Last Edit: September 12, 2015, 11:11:54 PM by Jerry Hall »
Offline KASEY
Big bore cylinders
« Reply #10 on: September 13, 2015, 12:31:18 AM »
ah crap... now I want COOKIES!!!!  DAMMIT JERRY.....
Big bore cylinders
« Reply #11 on: September 13, 2015, 12:55:58 AM »
Quote from: KASEY;58506
yea ,me too
Big bore cylinders
« Reply #12 on: September 13, 2015, 02:03:40 AM »
I just not sure what I want yet. when I got my bike it had a FMF fatty. Witch everything I had read said this to be bad for a 330. The original piston from this setup that I got in a box of parts with the bike. Showed the piston getting to hot by the exhaust port. So I switched to a bb boar pipe. Just not as happy with the power delivery. It was a trx5b cm. Now I have a lrd 350b I'm going to try. Wanting to get the power down a little lower. Just thinking the bb pipe might be just a little to big for this  330. So might just need to go a bit more.
Big bore cylinders
« Reply #13 on: September 13, 2015, 03:37:42 AM »
Hick, if you ever want to get rid of that 350b pipe, keep me in mind. I have been looking for one for a while.
Best regards
-Jsson
Big bore cylinders
« Reply #14 on: September 13, 2015, 10:20:28 AM »
yep no problem. I just had it ceramic coated.
