Author Topic: Longer kicker  (Read 8082 times)
Offline 2k1lvr
Longer kicker
« on: April 22, 2016, 02:10:00 PM »
Does anyone know of a kicker that is longer and will work? I've got alot of compression and I'm old and my knees getting bad! Lol
89 trx5 pipe 38as carb esr330 pv cyl ported by BUBBA RAMSEY at BHP,+4 crank,cr ign,elka front shocks,lsr axle
Longer kicker
« Reply #1 on: April 22, 2016, 02:30:53 PM »
I don't know of any longer kicker, but I have heard of some guys using a compression release. I would look into that instead.
Longer kicker
« Reply #2 on: April 22, 2016, 04:29:39 PM »
Quote from: 2k1lvr;66854
Esr has a dual plug and as Ryan said you could put a compression release they make them in the same threads as spark plugs available on amazon.
Longer kicker
« Reply #3 on: April 22, 2016, 04:44:31 PM »
350x kicker is longer.
Longer kicker
« Reply #4 on: April 22, 2016, 04:48:33 PM »
Depending on the exhaust you  have would ya have clearance issues ? With your toes or the kicker ?
Offline fourtrax
Longer kicker
« Reply #5 on: April 22, 2016, 06:24:42 PM »
Quote from: Skeans1;66860
Great idea!!
Longer kicker
« Reply #6 on: April 22, 2016, 11:29:25 PM »
Unsure on interference. Compared to ESR.
Offline 2k1lvr
Longer kicker
« Reply #7 on: April 27, 2016, 06:39:15 AM »
Great idea skeans1  I have esr billet head that came with my big bore kit.I wonder if I could install one on it somehow?
Offline dem3500
Longer kicker
« Reply #8 on: April 27, 2016, 08:18:12 AM »
i know on my trx5b a longer kicker would most likely not work. the kicker is close and as it is my toe hits the pipe. i would also like to look into a compression release. does the extra hole in the head affect the dome aspects at all? depending on the depth of the release into the hole wouldnt that affect the cc size of the dome?
Longer kicker
« Reply #9 on: April 27, 2016, 09:44:35 AM »
Possibly could affect the CC size of the head. I would be more interested in the burn pattern of using the one plug offset to the side.
Longer kicker
« Reply #10 on: April 27, 2016, 09:47:28 AM »
Quote from: 2k1lvr;66976
It'll need to be a dual plug head http://www.eddie-sanders-racing.com/product_p/billet%20head%202plug%20trx.htm [MENTION=1175]dem3500[/MENTION] there's pictures of the dome there too
Offline dem3500
Longer kicker
« Reply #11 on: April 27, 2016, 10:39:03 AM »
Quote from: Rupp250;66980
i would guess with that much of an angle you would have to index the plug
Offline dem3500
Longer kicker
« Reply #12 on: April 27, 2016, 10:47:50 AM »
just by looking at the pic, id say the plug is on the same angle as the single plug head
Offline dem3500
Longer kicker
« Reply #13 on: April 27, 2016, 10:54:29 AM »
use the dual plug head and a standard dome. drill a small hole from the second plug location in the head into the dome. that way you dont have a really big hole that may affect the CC of the dome. i have no idea how big of a hole would be deeded for enough decomp to actually feel a difference but if you started small you could always go bigger
Offline dem3500
Longer kicker
« Reply #14 on: April 27, 2016, 11:00:17 AM »
this?
http://www.amazon.com/TP-Engineering-Compression-Release-45-4020-21/dp/B000WP1SV8/ref=sr_1_1?ie=UTF8&qid=1461769139&sr=8-1&keywords=motorcycle+compression+release
