Author Topic: Tips and tricks  (Read 36225 times)
Re: Tips and tricks
« Reply #15 on: December 08, 2022, 02:20:58 PM »
For anyone that wants to replace their Rusty & corroded Rear Master Cylinder rod - the Suzuki (Part#69670-00A00) fit's like a charm!
I recognize that rear MC :) It's been working 4 years now with the Suzuki push-rod & had no issues.
Offline atvmxr
Re: Tips and tricks
« Reply #16 on: December 09, 2022, 11:21:34 AM »
If you lose the discontinued collar that goes with the bolt that holds your front OEM fender in place.....no worries...just replace it with this HONDA Part#90104-MEN-A30.....It has the shoulder built into it!
:D
thank you!  i had a post somewhere where I was talking about how I thought the R came with an encapsulated collar, but no one knew what I was talking about.  guess the previous owner swapped them out
Re: Tips and tricks
« Reply #17 on: December 09, 2022, 05:12:12 PM »
If you're looking for the rubber grommets that go on the frame pegs to support the front of the Air Box (Honda Part#  19032-HB9-000 - DISCONTINUED) Item# 28 on the Air Cleaner fiche - Have no fear! YAMAHA has a grommet that works perfectly!
YAMAHA Part# 90480-12053-00
 ;D
Re: Tips and tricks
« Reply #18 on: December 12, 2022, 08:31:12 AM »
John, nice find on the air box grommet and shouldered fender bolt.
« Last Edit: December 12, 2022, 08:32:44 AM by croat1 »
Re: Tips and tricks
« Reply #19 on: April 08, 2023, 08:17:27 AM »
If your exhaust flange has no spring mounts you can use some #428 chain side plates.  Drill and bend as needed.
« Last Edit: April 08, 2023, 09:40:30 AM by croat1 »
Re: Tips and tricks
« Reply #20 on: January 31, 2024, 05:32:35 PM »
Air box filter sheet
Re: Tips and tricks
« Reply #21 on: February 01, 2024, 09:00:43 AM »
Cable operated choke
Re: Tips and tricks
« Reply #22 on: September 26, 2024, 10:04:26 AM »
Oem 8 plate clutch
Re: Tips and tricks
« Reply #23 on: May 08, 2025, 02:46:35 PM »
Another faulty CDI fix is to heat it in the oven.
http://pilotodyssey.com/PO/viewtopic.php?f=24&t=18604
« Last Edit: May 08, 2025, 02:52:25 PM by croat1 »
