Author Topic: Tips and tricks  (Read 27052 times)
Tips and tricks
« on: February 28, 2021, 08:49:14 AM »
Clutch actuator arm modification.  Not the best pic but easy enough to understand what has been done.
Re: Tips and tricks
« Reply #1 on: March 04, 2021, 12:21:08 PM »
Additional stock cylinder sleeve protection during storage or shipping.  Take the core from a used up roll of packing/shipping/duct tape.  I remember seeing this tip many years ago.
« Last Edit: March 04, 2021, 12:34:47 PM by croat1 »
Re: Tips and tricks
« Reply #2 on: March 04, 2021, 02:19:49 PM »
i use a scrap piece of pvc
Re: Tips and tricks
« Reply #3 on: January 28, 2022, 08:01:17 PM »
Who remembers doing a stator cover vent.  I never did it.
Re: Tips and tricks
« Reply #4 on: January 28, 2022, 08:03:50 PM »
Seat foam repair tip from the late Michael S.
Re: Tips and tricks
« Reply #5 on: February 04, 2022, 06:25:17 PM »
I never put a vent in the magneto cover, but I have put drain plugs in a lot of covers.   I would put the  drain plug in the lowest part of the cover and removed the plug after the bike has been ridden in water or after it is washed.  I would leave the drain plug out and install it just before the next ride.  It allows any moisture that may have leaked in around the wire sheath or wire grommet to evaporate.
I have worked on many 250Rs that had a good mag cover gasket and wire grommet that had a completely destroyed mag side crank seal.  The bike ran fine and did not have any symptoms of an air leak.  For this reason would not put a vent on the cover that was open to the atmosphere when the engine is running.
Re: Tips and tricks
« Reply #6 on: February 06, 2022, 07:11:26 PM »
Makes sense. Thanks Jerry for your input.  Greatly appreciated.
Re: Tips and tricks
« Reply #7 on: May 25, 2022, 10:48:16 PM »
Seen this searching.  Too good not to share.
Re: Tips and tricks
« Reply #8 on: August 03, 2022, 07:14:51 PM »
Might save the day…faulty CDI fix?
« Last Edit: September 05, 2022, 11:30:02 AM by croat1 »
Re: Tips and tricks
« Reply #9 on: August 26, 2022, 10:46:38 AM »
Front Brake line tip.
Re: Tips and tricks
« Reply #10 on: September 11, 2022, 10:11:08 AM »
Here’s a good link for softening rubber parts that have hardened.
https://v4musclebike.com/forums/showthread.php?t=13477
Re: Tips and tricks
« Reply #11 on: September 11, 2022, 01:55:46 PM »
That's very useful. Thank you
Re: Tips and tricks
« Reply #12 on: December 08, 2022, 09:43:07 AM »
If you ever need to FIX a Bent or crushed Foot Peg.....Here's a simple tip!
Take a M8 fully threaded bolt......insert it into the hole in the middle of the peg....or where the bend is.
Install a nut....screw it through the nut.....and then install a 2nd nut......thread it through so the threads come out the other side of the peg.
Now using a wrench.....tighten the first nut against the peg and then the 2nd nut.....using it like a spreader to push out the dent!
VOILA!
LOOKS LIKE NEW!
 ;D
Re: Tips and tricks
« Reply #13 on: December 08, 2022, 11:53:56 AM »
For anyone that wants to replace their Rusty & corroded Rear Master Cylinder rod - the Suzuki (Part#69670-00A00) fit's like a charm!
Re: Tips and tricks
« Reply #14 on: December 08, 2022, 12:01:46 PM »
If you lose the discontinued collar that goes with the bolt that holds your front OEM fender in place.....no worries...just replace it with this HONDA Part#90104-MEN-A30.....It has the shoulder built into it!
:D
