Workshop
Suspension and Chassis
Rear Axle
Topic: Rear Axle (Read 7597 times)
Vegas_Trx250r
Rear Axle
July 26, 2022, 07:51:48 AM »
I bought a new rear axle, swing arm, and bearing case. Do I grease the axle before I install it into the bearing case?
New to the ground up build.
croat1
Total likes: 947
Re: Rear Axle
July 26, 2022, 08:48:02 AM »
I always do. Don’t forget to grease the rotor hub splines and nut threads.
(1 person liked this)
The norm
Total likes: 327
Re: Rear Axle
July 26, 2022, 09:21:35 AM »
Yes grease the axle and the splines. It makes life easier when doing a future teardown and will also make the splines last a little longer.
Loren
Vegas_Trx250r
Re: Rear Axle
August 21, 2022, 10:17:39 PM »
So, I headed the axle up. Do I need to compress the axle into the bearing carrier?
broken1
Total likes: 156
Re: Rear Axle
August 22, 2022, 01:34:27 AM »
The axle bearings are a slip fit so the axle should slide right into the carrier.
bunk216
Total likes: 8
Re: Rear Axle
August 22, 2022, 03:46:18 PM »
Kind of what he said above, I actually just installed the same exact axle in all their same parts and nothing extra was needed. Just greased and slid right in.
89' 250r LED 390, Lonestar, Elka, etc...
Langbolt
Total likes: 62
Re: Rear Axle
August 24, 2022, 10:26:50 AM »
@Vegas_Trx250r - Watch this
https://youtu.be/RgZQjIxifls
Workshop
Rear Axle
