Author Topic: what did you do to your R today?  (Read 140638 times)
Offline Pricecheck
« Reply #270 on: July 17, 2014, 08:25:24 AM »
It wasn't today I did work but a couple of days ago I decided to tinker with the hybrid. Yfz motor sits 3/8" lower than frame so I have to box out the frame for protection. Mocked up an engine cradle so I can fab some motor mounts. Also cleaned up all of the unused mounts. Then I trimmed up the stock cdi mount and fabbed it to accept the yfz cdi and rectifier thing.
Not complete but I extended the mount to fit the rectifier and thinned the top plate to allow the cdi to attach. FYI.... I'm calling the black box thing the cdi. Maybe it's a distribution box.
Offline Pricecheck
« Reply #271 on: July 17, 2014, 08:26:49 AM »
The cdi slides on the tab. The rectifier mounts to the base once I weld some studs on it. It does clear the steering stem.
Offline Bigred
« Reply #272 on: July 17, 2014, 10:02:43 AM »
Put it on the trailer ready to go to pinelake
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
Offline aberegg05
« Reply #273 on: July 17, 2014, 10:51:09 AM »
Installed a pwr radiator yesterday. Hopefully thatll keep the heat down
« Reply #274 on: July 17, 2014, 11:27:49 PM »
Just finished up mounting the trx5b cm and led intake I got from Mando.
« Reply #275 on: July 18, 2014, 12:21:05 AM »
Heard my R run today for the first time in 2 years. Third gear went out in my engine, I picked up a spare engine last winter off craigslist & put my top end on it. Went from a long rod to a short rod.
Offline mgleason05
« Reply #276 on: July 20, 2014, 09:41:24 AM »
Replaced the handlebars, new hand guards, new rear tires, and new chain and sprockets.
Offline zcarlson12
« Reply #277 on: July 20, 2014, 03:19:24 PM »
New chain and sprockets installed. Mounting new LRD pipe this week.
Offline ytman
« Reply #278 on: July 21, 2014, 06:45:31 AM »
Pictures...pictures.....pictures
Offline zcarlson12
« Reply #279 on: July 21, 2014, 07:32:32 PM »
As requested:
Offline Trusty2stroke
« Reply #280 on: July 22, 2014, 12:23:31 PM »
This was over the last few days. Installed new crank seal, clutch plates, had counter balancer rebuilt, and installed new graphics.
Offline ytman
« Reply #281 on: July 22, 2014, 05:31:56 PM »
Quote from: zcarlson12;39602
As requested:
MMMMMMMMMmmmmmmmm thank you
Offline supernutt
« Reply #282 on: July 27, 2014, 09:02:48 PM »
Installed my "new to me" afco radiator in my trail machine.  Seems to work pretty darn good.  I can really feel the heat coming off it.  Thanks kt23!!!
Offline jamieg45
« Reply #283 on: July 29, 2014, 02:11:45 AM »
OK Saturday, I pulled the axle and anti fade nut off of the Walsh. So burns363r kyle could use it to race on sunday.
Sunday I pulled the stem out of the lsr at my parents house so I can ship it. Monday after work I put the rear of the Walsh back together and put the mx tires on her so I can race on friday. Piston is in as well so top end will be finished up tomorrow after work.
01 Lsr 250r
00 Walsh 250r
Offline 08IRS
« Reply #284 on: July 29, 2014, 10:57:06 AM »
Just finished installing the CT pipe and silencer.  I hope to install the radiator shrouds and front plastics today.
