Author Topic: CR500 swingarm - who is building these in 2016?  (Read 9956 times)
« on: April 10, 2016, 09:57:22 PM »
Who is still setup to build cr500 link swingarms?
« Reply #1 on: April 10, 2016, 11:53:56 PM »
Laeger for sure.  maybe JD Performance can? its worth a call.  Six 5 Design might (they were in the process of making a jig last time I was there)....not sure if was a CR link.  Steve B. (is he a member here)?  Sorry for not having a true answer to your question but some possibilities are better than nothing.  good luck on your hunt!!!
OJ: just seen your post....Steve Buchinsky. I see you have already asked.
« Last Edit: April 11, 2016, 12:18:31 AM by croat1 »
« Reply #2 on: April 11, 2016, 01:11:39 AM »
Quote from: croat1;66492
Thanks Joe. Good suggestions!
Offline zcarlson12
« Reply #3 on: April 11, 2016, 08:50:06 AM »
It doesn't show on their website anymore but I'm sure Walsh could build one being a site sponsor. May have to give them a call though.
Offline dem3500
« Reply #4 on: April 11, 2016, 08:59:59 AM »
i diddnt know JD made swingers. if he does i wouldnt hesitate to buy from him. i bought arms from him and hes a stand up guy that stands behind his work 110%
Online Langbolt
« Reply #5 on: April 11, 2016, 09:00:26 AM »
Would making a swingarm that utilizes the Yamaha link be an advancement ? Since the CR500 Link is obsolete.....and the Yamaha Link is readily Available ?
Or use the YZF450R Swingarm ? It is Cast Aluminum....so it would save some weight and possibly give you the Setup you're looking for ?
Just a thought..... :D
Offline pressure262
« Reply #6 on: April 11, 2016, 10:20:01 AM »
Cr500 links are available in billet now through ISF Racing. Super nice and affordable. They come with bearings installed too!
« Reply #7 on: April 11, 2016, 12:23:58 PM »
CRF450 linkage would be the way to go
Offline Lasher 19
« Reply #8 on: April 11, 2016, 01:25:59 PM »
My Walsh 250R has the CR500 swingarm linkage. My son's Walsh CRF hybrid has the 450 swingarm linkage. Both have Custom Axis rear shocks installed and when I sent them to Custom Axis for set up, there was a slight difference between the two linkage types when it came to shock lengths.
My son's could get PRS while mine could not. :(
« Reply #9 on: April 11, 2016, 01:32:18 PM »
But the CRF450 doesn't directly bolt up to an existing CR500 link frame and CR500 link swingarm, correct?
Offline Lasher 19
« Reply #10 on: April 11, 2016, 01:54:56 PM »
It has been a while since I compared the two but I do not think it is just a straight swap. I think the frame part is identical (again not sure) but the linkage is different.
Offline dem3500
« Reply #11 on: April 11, 2016, 02:37:54 PM »
is there any linkage that would bolt right up? obviously the shock link would vary.
Offline Lasher 19
« Reply #12 on: April 11, 2016, 02:43:16 PM »
From my limited knowledge of shocks and linkage, while "any" linkage can be bolted up, the leverage ratios and movement need to be ok from a "fitment" side and also the shock building must know those ratios to properly set up the shock.
I do know that the frame connection for the shock using the CR500 (or CRF450R) is MUCH different than stock.
Offline 89Longrod
« Reply #13 on: April 12, 2016, 11:58:34 AM »
This is a comparison photo of Cr500 vs Crf450 linkages I took a few years ago when I was building my quad. The one back one/right side is the cr500 linkage, I cant remember if the CRf fit sorry :/
« Reply #14 on: April 12, 2016, 03:49:49 PM »
tyson racing could probably build you the swingarm that you need.
